You're taking this car apart to re-do?
Sure is pretty, but I can kinda see why there are fewer of them.
Just to clarify, the entire car is not being redone. There are some fitment issues with the body panels which are being addressed as the early repro quarter panels did not fit well to where the rear valence was and the recessed area where the gas cap was is a bad stamping and not crisp lines like it should have been like original so we found an original "patch" panel and had that welded in. Now the gas cap actually sits flush with the body now. BIG improvement compared to what it had been. Also, things that should have been painted body color weren't prior to us buying the car when it was restored how many years ago. Items such as hood hinges, bolts for fender to inner fender, etc. And other items that were painted body color that were either natural or zinc from the factory will be put back to factory appearance.
