Looking at the Carter rotary vane pump. Reading around on this a little, most seem to recommend using a parallel line around the elec. pump with a check valve. Would you say this would be good practice, Mike?
I've never done it... to me the check valve would have
to be big... same ID as the line... but I've never done it...
I either run a mech or a elec... but thats me
