Anodizing does make the surface of the part harder
Not regular clear or color anodizing. Only "hard anodizing" makes the surface harder. Hard anodizing has no color pigment and would be used on wear surfaces - much like "hard chroming" steel. Neither are meant to be pretty.
http://www.anodizing.org/Anodizing/benefits.html
