I would be happy to sell the front and rear bumpers off of my 71 Demon if anyone is interested. $150 for both or $100 each.
I can also pull the shortened 8 3/4 out of the car. It is backbraced, set up for 4-link and coilovers, Richmond 4.88 gears, Strange Spool, Strange axles with 1/2" studs, Mark Williams 1350 yoke. Don't have the dimensions with me off hand, but I can fit a couple 32 x 14.5W slicks under it with a 15" wide wheel with 4.5" backspacing. I just went through it last season, then only raced it in one event. IIRC there's more than $1300 invested in it. Would like to get $850 for it. If interested PM me and I can get exact dimensions.
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
