Building a new drag car and I thought I would share with you all. I bought this car last September thinking it would be some what race ready. However once the car was home we found out it needed much more work then we thought. It was tubbed poorly and had a 6 point cage. We removed the old cage and tubs and installed a four link with a 12 point cage. We still have the interior to finish but it's coming together nicely. The motor is a small block stroker with ported w-5''s, bullet cam, and Indy intake. "Small blocks ROCK!" Should be a nice little bracket car. Here are a few photos. I'll post more as the build goes!
