Quote: My add to this problem is that I had a bad wire in the ignition harness where it plugged in to the the switch. Another possible problem is a bad connector in the firewall bulkhead connector for the ignition run switch.
Also the ignition switch itself could be bad.
i agree- the orginal problem- as you turn off the ing. key there is enough connection to give spark!
