Re: sixpac guys, HELP
[Re: GLR]
#1755764
02/19/15 03:08 AM
02/19/15 03:08 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I just contacted Summit Racing, Yes..Holley does make an electric choke kit for the Holley 2BBL centre carb. This is the Holley Electric Choke Conversion Kit number 45-224 So... They do exist...
That kit will work great after you make a custom mount and linkage to clear everything. Holley does or did make a six-pac setup for smallblock chevies that had a different center carb casting, that had electric choke and looked like would work but I never bought one to try it for sure. Sell your carbs and buy a set of those and your problems are solved. Go to Summit and take a look at SUM-CSUM1900,go to the close up of the center carb, and you will see the mounting bosses your mopar carb does not have. I have done this on mopar carbs with the kit you mention, you just need to mount it with a bracket, make linkage, and hook up the vac line, works great.
Entire Thread
sixpac guys, HELP
Moparnut426
02/16/15 03:53 PM
Mr.Yuck
02/16/15 04:28 PM
3hundred
02/16/15 04:34 PM
Moparnut426
02/16/15 05:04 PM
3hundred
02/16/15 05:13 PM
Moparnut426
02/16/15 06:07 PM
lokalik
02/17/15 04:01 AM
mopar346
02/17/15 04:15 AM
screamindriver
02/17/15 04:30 AM
Moparnut426
02/17/15 03:48 PM
TJP
02/17/15 05:14 PM
GLR
02/18/15 02:31 PM
62maxwgn
02/18/15 03:07 PM
GLR
02/18/15 03:40 PM
62maxwgn
02/18/15 04:42 PM
TJP
02/18/15 08:04 PM
72roadrunnergtx
02/26/15 07:15 AM
62maxwgn
02/26/15 02:30 PM
TJP
02/26/15 04:35 PM
4406bbl
02/19/15 07:08 AM
GLR
02/24/15 11:13 PM
GLR
02/24/15 11:14 PM
GLR
02/24/15 11:15 PM
62maxwgn
02/25/15 03:39 PM
GLR
02/25/15 11:30 PM
TJP
02/26/15 04:41 PM
Golden-Arm
02/19/15 01:37 AM
sogtx
02/26/15 12:44 AM
GLR
02/26/15 01:38 AM
62maxwgn
02/26/15 06:31 AM
