I had RHS bush some Comp Pro Magnum a few years ago. They didn't bore out the rockers. They press in a bushing and use a smaller diameter rocker shaft. I have an extra set of their shafts if interested.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
