We use these cams with the Indy rockers and retainers with good results.Choose a good spring with aprox.225 to 250 lbs on the seat and 500 to 600 lbs. open.For best upgrades use 10 degree titanium retainers and 10 degree locks then you can use a little more spring pressure if you want.
Those pressures are a lot higher than the Comp 925-16 springs.
I was just going off the "recommended parts" in the Comp catalog. If anyone could point me in the right direction it would be greatly appreciated!
