it is worth pondering the
"crevice volume"
effect
crevice volume is generally thought to be a bad thing
because it 'quenches' the flame and creates unburned hydrocarbons ... which reduces both power and fuel economy
there is crevice volume in the little gaps of the head gasket joint
there is crevice volume in the 'ring land' from the top of the first ring to the piston crown
could the undesired two crevice volumes
be combined
to eliminate a bit of both?
some engine builders try to do this
by having the piston come above the deck
enough to cover the head gasket joint
during the peak of the combustion event
it is an approach that might gain a bit of
in one of the last 'Engine Masters' competitions one of the top engines had a very large value for positive deck and this may have been one of his strategies
there is also a small effect in being able to use a tiny bit longer connecting rod
it is worth thinking about
another small detail
"The Devil is in the Details"
I like that idea as you described it.mike
