Hello all. I've done some calling and info collecting on my fuel pump push rod. My cam is a billet cam shaft, that's why I need to use a "brass" tip fuel pump push rod. Yes, from talking to a part seller they are a wearable item (I had no idea, someone also pointed this out). Seems several of you have had some push rods that have lasted for a long time in the engine. Racepumps.com tech said their brass tips are of a different metal combo, are harder and wear better and work on billet cams. May go that route and see how their product wears. I'm still working the issue, just want to be sure I get a quality part in to alleviate un-necessary fuel pump removals over time as well as protecting my cam and using the correct part. Any more info would be greatly appreciated. Thanks!
