Be happy that on the E body the gear change was an Axle package and there was a code.
On the 67-69 A bodies (also Hamtramack built) built with a performance axle ratio there was no code so the only way to know is with factory/dealer documentation.
Yup, and that's because the A-body kept the same radiator support regardless of the gears. I believe it was the same way for the '70-71 A-bodies as well.
