That 47 will never live. You can build it with the 48 5 -gear planetary's, but the weak link will always be the overdrive clutch/spring. You can update to a 48 overdrive, but by then, you could just use a 48...and the 48 won't live either with that torque. You've got options, but none are cheap.
