Hi Dan, please give me the low down on your connectors. What level of chassis stiffness can I expect verses weld in and will they be visible looking at the car from the side, will I lose ground clearance ..... Thanks!
These tie the chassis together on a second plane and tie the rear subframe to the front subframe at the strongest points. They require minimal welding on the B/E cars. The lowest point of the connectors will be at the torque box, and they run about 1/4" from the floorpan. Here are the instructions for them which have a lot of good pictures that will answer a lot of your questions.
http://www.hotchkis.net/_uploaded_files/4011S.pdf
