First I'm going to try a spicer u-joint ASAP. I hope it's not the drive shaft. I replaced it 2 years ago after another u-joint failure that happened shifting from 2nd to drive at 94mph with the automatic. That was scary.
Hogs head may be the Ford word for "The chunk."
For those of you who may not know, 74Rallye is a former Ford guy. "Forgive him, he knew not what he did." Obviously, he has returned "from the dark side."
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
