most i have seen the clutches were out and you dont know when the bearing gave up---but i have pulled a couple junkyard nv4500,s and dont know how many miles were on it and they also had bad pilot bearings----made me wonder if the solid brass ones are better----you would think a person in a cummins shop would have a good idea of how long those little pilot bearings last.....
The pilot bearing in my gasser rig with an NV4500 broke down and the needle bearings got swedged so bad to the input shaft that the clutch would not disengage. It was all rusty and dry as if it was never greased when new!
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
