Re: 555 to 572 C.I. vacume pumps, who's good?
[Re: dvw]
#1705975
12/04/14 03:33 PM
12/04/14 03:33 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Running a 528 wedge, I tried a GPZ years ago, couldn't pull enough to show 3 inch vacuum. Went to a Moroso three vane, got max 10 inch running 50 percent engine speed. I suspect the four vane enhanced Moroso would be ideal, as you can regulate it down and run it fairly slow to get the same results, improving pump life.
My GPZ will pull 7-8 at idle. Doug
The year was 2003, and the pump was a converted Pinto smog pump. I believe they were GZ then? I called them three times and they never responded. So they have one dissatisfied customer. Glad your pump works. They may have totally changed their product since, but you know how it is. Burn me once,,,,,,,,,,,
Entire Thread
Cab_Burge
12/02/14 09:07 PM
WHITEDART
12/02/14 09:19 PM
Al_Alguire
12/02/14 09:33 PM
an8sec70cuda
12/02/14 09:37 PM
rickseeman
12/02/14 11:31 PM
AndyF
12/02/14 11:45 PM
dvw
12/03/14 12:52 AM
camastomcat
12/03/14 01:15 AM
sjs64polara
12/04/14 04:15 AM
sasquatch
12/04/14 06:22 AM
MR_P_BODY
12/04/14 06:29 AM
gregsdart
12/04/14 12:15 PM
dvw
12/04/14 01:21 PM
gregsdart
12/04/14 07:33 PM
MRMOPAR622
12/04/14 11:39 PM
dvw
12/05/14 02:27 AM
evenflow
12/05/14 04:31 AM
1320Dart
12/05/14 02:34 PM
