Wilwood Mopar rear discs with drum parking brake will only install easily if...
1. You order the kit for 2.36" axle offset and SNAP-RING Green bearings
2. You have aftermarket axles, access holes in the flange, 1/2" SCREW-IN lug studs with narrow hex-heads and very thin washers
3. You remove the thurst block inside the differential
Otherwise, machining is required.
...Then, you are on your own for the parking brake cables.
lokar makes the brake cable kit:
BB, TT5,Procharged 3300lb Street Car 4.79/154
