Anybody have an idea of the exhaust port height difference between an 440 block with standard type heads/ Eddie RPM vs. a 400 block with raised exhaust port Indy 440-1 heads?
I believe that the 400 is 3/4 inch less deck height than a 440, how much higher is the Indy heads than the Eddie?
Thanks in Advance
JN
