Re: Bad Alternator?
[Re: Got2Gnow]
#1702942
11/25/14 08:34 AM
11/25/14 08:34 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Sorry, it is a 1971 Swinger with a 318, auto, A/C, PS, manual brakes (was 4 drum, now front disc/rear drum).
I was told to turn the key ON (engine OFF) and hold a screwdriver in front of the pulley and feel for a magnetic pull to the pulley. I tried with NO magnetic pull. I then started the engine (volt gauge ~10-11V) and tried the screwdriver magnetic pull test again. I felt NO magnetic pull (front or rear).
The "poor man's" alternator test is to put a screwdriver to the rear bearing located in the center of the alt in the rear case, WHILE THE VEHICLE IS RUNNING, if you have a magnetic pull enough to slightly hold the screwdriver in place then your system is making a complete charging circuit,...you need a meter to properly evaluate each component in the system for proper troubleshooting
