As far as I know small block mopars do not benefit from a T ram like the big blocks do.
Back in '87 I ran an Edelbrock t-ram on the '67 Cuda. Little 340 with 10 to 1 and the Lunati BR II cam, only .480 lift, 234 at .050 and ported lightly 340 X heads. Two Holley 450 carbs. Power range was 3000-6000 rpm and was real nice to drive on the street. I could drive 150 miles one way to Cedar Falls Raceway in Iowa and run 12.20's in street trim. Worked good 22 years ago and they still work good today, all in the setup.
Snap your neck, mega G-force launch, is all I want!
