http://www.ctci.org/gilsgarage/ValveGapperInstructions.phpI too remember them. Would make a solid lifter engine sound as a well tuned sewing machine when all valves were perfectly dialed in. The best solution for worn rockers.
A bit messy with engine running. In those days, did not seem as big a deal as now.
Don't know if had a kit for Hemi engines. Each engine required proper adapters.
Would be just the ticket for our 300 B.. However must pull generator/power steering pump combination to remove driver side valve cover,,,then re-install to start engine for adjustment of valves with engine running,,,could skip this re-install I suppose and idle engine with belts(there are 2 on dual groove generator/PS pulley) left off.
http://www.ebay.ca/itm/VTG-1956-P-G-Valv...2cc1&_uhb=1
