Yes the whole bell flexes so the transmission mobes away from the motor when pressing the clutch. Cant see that thf issue would be anywhere else.
Its only a very small amount but i can see it.
If the trans is moving away from the bell housing you have some OTHER issue. There should not be enough force just overcoming plate load to move or flex anything.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
