Thanks for all the replies. I have two problems the tumbler is just plain worn out after 175,000 miles. Problem two is when I go from run to start I loose power to all of my electric accessories fuel pump, water pump and will sometimes not even send power to the starter. I assumed the ingnition switch is bad. Any other ideas?
