mine is a B body. I used a similar coupler and gutted the upper shift bowl. The portion where the shift handle attached was opened up to access the release button. Then I spun a 1/8 aluminum disc and tacked it to the hub. I epoxied the bowl to the disc since it was pot metal. Here's the results.
Doug
