I have two solid rollers to try w/ my new engine combination. One came from Dwayne Porter (802)951-1955 (who also spec'd & supplied my last solid flat-tappet cam) and the other is from a company that was also mentioned above with whom I've had no other prior experience. I won't mention who the other company is, simply because I have no results on which to base a recommendation.
