Guys,
I may be trying to get my door panels (73 Charger) back together here and I have a question about putting in the plastic sheeting behind the panels. Do you guys put that back in when you re-do your doors?
My plastic sheeting is long gone as it was torn to heck when I pulled the panels years ago. Should I be worried if I don't make new sheeting or just leave it out and go?
I'm guessing it was there for condensation not rotting out the backs on the interior panels but mine were still pretty bad.
If I do need to replace it, what do you recommend to use as the glue/putty to re-attach to the door? Also does anybody have a picture of this from a 71-74 B-body?
Thanks!
