Quote: If you install an A13 inner bearing and race, the earlier C-body rotors will fit '73 and newer A/B/E/F/M/J/R body knuckles without an adapter. I never looked into a seal for that combination, however.
Are they the 2 piece rotor/hub? So the earlier C body outer bearing is the same as the 73 and up E body but it's inner is different?
