Quote: Are A-bodies non-existent in California junkyards now? I think you'd probably sleep a lot better at night knowing you had a "seasoned" set of knuckles in light of this.
I have a set of 73+ A body drum spindles but they don't work with my brake setup as I found out when I tried to install my brakes. I believe they work with some of the other kits though. And the Local Pick-a-Parts rarely have A-bodies and if they do, they're picked dry within days. You'd have to purchase a parts car.
