I was looking for the correct 1" bore m/c for my big block A body. The particular unit is pretty much unobtainable. Got with the Ramman. He set me up with a unit that had a 11/16" bore which is pretty close. I've since found the correct numbers correct unit which he's restoring so I won't be needing the one he setup for me.
