Its a fresh motor just changed the cam, and it was running sluggish, so I was concerned that the cam was in a tooth out (retarded) so if it was, the compression would be low, not sure how low, but for sure not 160#.Had the timing at 37deg. had to go up to 45deg for the motor to act rite, got lots of power at 45. I think my timing lite is toast.
"SHOULD HAVE DEGREED IT IN"
