if I put a b-engine(400 block) in a 68 a-body that has a v-8 k-member using the Schumacher mounts will the TTI headers fit?
thanks
Russ
I have never used the Schumacher mounts but I do have a 400 in my sons 72 Dart and we used a bigblock A-body K-frame from a 68 Cuda and the 2" CPPA headers which look just like TTI's as I believe TTI took over the CPPA headers. The 2" CPPA headers fit fine in my boys Dart with that setup. His car is a 400 that had 452 heads and now is using RPM heads and the headers fit great with both heads. Hope that helps some. Here is a pic of his pass side I took while adjusting the valves. Ron
