Quote: The Pentastar-shaped head was not introduced until 1970 -- to fit the column-mounted lock cyl.
Rick
Correct, 69 uses the rectangle head, same at 68 and earlier, but Mopar changed vendors for 69 (Yale I believe) and the long milled slot is in a different location than previous and all the teeth are different heights so the lock pins do not interchange.
