Just Scored a 5.9 Magnum out of a 98 Ram 1500. plan on doing the Carb conversion. Going to run the stock bottom end and stock heads along with the 5.9 Roller Whiplash from Hughes. In keeping with the stock heads what intake would you guys recommend and also what size carb would be best? It is going in a 1977 Shorty Stepside
