Hello I am making progress on my suspension. I have a 71 dart with qa1 lower control arms. I purchased the hotchkis front and rear sway bars and the instructions indicate that they are weld in. Do all all of them need to be welded. If so does anytime have better instructions. The ones that came with the bars are terrible
Thanks joe
Sorry you are having trouble with the instructions. Here are the digital instructions, complete with full color pictures, they may be able to help you a bit more.
http://www.hotchkis.net/_uploaded_files/22385.pdf
For your kit you will have to weld in the mounts on the K frame as well as tabs on your lower control arms. I don't know if the QA-1 units come with provisions for sway bars.
