You may know this already, but depending upon what the Dana 60 housing that you have was originally made for, it may have 3" OD tubes or 3 1/8" OD tubes so you need to determine that before ordering the tubing. In either case, the tube ends will need to be machined down slightly in order to have the proper press fit into the housing.
