Thanks for the answers. I'm thinking i need another 1/8 inch. Bob you said steel shim under the spacer, would copper work over and under better? I could cut the copper flush to the spacer, rings are lower so no interferance just don't want any gaps. Should i drill and tap the bolt holes deeper, i'm using studs?
