down and up max speed 12 times each hole
Will make a difference of what grit dingle ball you use
Yes,coarse will make the hone more aggressive and the deeper.Only use it enough to clean and scuff the bore, too rough will kill the rings and keep more oil on the walls and cause poor oil control.The finer the finish the better.
