What do you mean "the smaller ones" Bill? Are there 2 different size studs on those taillights?
Jim,/like mentioned 1970-71 Barracuda ( 1970-71 Fury is the same ) is an odd duck, they require 4 fasteners per sidemarker when most other cars only require 2 per light.
The larger acorn nut is the same as the sidemarkers on most 1969 B and A bodies. ' Also the same nut as on the tail light on 1970 Plymouth B body
AMK was the manufacturer ,but dis-continued a few years back . RT Specialties might have some . I bought the remaining stock AMK had back then and have very few left to use for in house shop projects
