Need a little help. I need to install two Jesel keyway lifter bushings in my hemi block, and Jesel normally has the tool to use, but have been out for the last 5 weeks. If an engine builder has the Jesel installation tool and would rent/borrow it to me, I would be very grateful. One day turn around and right back to you. Thanks, Dan 763-227-3366 or dyno5583@aol.com
