Haven't had a chance to check it yet (being retired is great
Arent those solid axle front ends? If so there must be some sort of bent component.
Still has BJs and a unit wheel bearing.
They use a sealed unit bearing on the front. Its sold as a complete unit, they can be a pain to replace if they have seized.
They are a known wear item, especially if you run a larger than stock tire.
Stock tires (except for a brief time when I had some 285 Muds on it). From what I've been able to find, it can be either BJs or the wheel bearing assembly. Neat video on youtube about how to push the hub out.
https://www.youtube.com/watch?v=gpH0SlYS6YM
Tim
