Get one of those antifreeze testers and see what it says. They aren't but a couple of bucks.
The old traditional ones only tell you is the freezing point.
And he's in Florida.
A coolant test strip that show PH and then Reserve Alkalinity is needed with the newer non green coolants.
A simple electrolysis test reading under 300mV is helpful too.
