Re: 557 Purpleshaft - How fast have you gone?
[Re: joedust451]
#1667287
09/04/14 12:43 AM
09/04/14 12:43 AM
Posts: 5,167 CT
GTX MATT
CT
Not the PS .557, but i ran a best of 10.91 @ 120.56 (on a 1.51) with an XE284H cam, completely stock 906s, 9.73 compression, M1 intake, 750dp, fenderwell 1.7/8 headers, 4400 stall, 4.10 gears shifting at 5600, race weight was 3150. 75 duster.
Went to a solid comp 282S cam, ported the heads still keeping the stock valves, Wieand TR with 2 600s, 1st. pass un-tuned, On a bad 1.63 60ft. in the heat it ran 10.87 @ 123.58 shifting at 5800
So high tens are doable at 31-3200 lbs. with the .557
[Edited by Moparts - Family Friendly Site - Keep it clean], I'm actually asking because I'm running the XS290S in my 440 powered B body, I hope it makes the type of power you did with the 282S. I'm hoping for low 11s but expecting mid to high 11s.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
