chris you have a mopar head,, these are the edelbrock mopar heads, i did a minor bowl job as you wanted to those cause you didnt want your motor to make too much power,, so those numbers ootb are with some blending,, not much though.
ill post the numbers off bob's heads tomorrow,, before,, then once done,,, after...
jeff
