I had a similar issue but it was the cam sensor. Turned out to be the alternator.
Personally I would try a new cam sensor and see what happens first.
Also, how are you getting the codes?? Cheap scanner or are you doing the "key dance"???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
