There are a few different versions of the 200S (aka Daisy, aka Coke Bottle).
The originals are one piece cast aluminum with a machined lip, much like the Torq Thrust D. I believe these were introduced around 1969. I had a set of these, and it took several years of hunting to find a matched set of 15x7 and 15x8.5. 14-inchers are far more common.
There were also some 16-inch bead lock produced for slicks.
In the early-mid 70's they came out with the modular two piece wheel [edit]called the CP 200 [edit] (as you have) utilizing the chrome steel rim. Most all of these you'll come across are rusted beyond repair. As with most chromed wheels of the era, they didn't weather very well.
In the last 5-10 years they reintroduced them as a two piece polished aluminum design. You can get them in 15 and 17 inch sizes.
As with the Torq Thrust, there were a few copies of the original style made by other companies. I've never seen any knock-off of the later styles.
