1997, V6, stick. When I let off the gas to shift, the RPM's seem to hang between 12-1500rpm's, the after a couple seconds, drops back to around idle (just at/under 1000rpm's).The last couple days it sometimes revs up to around 2000, then drops back.
I wouldn't think it would be the cable, but is there a relay or sensor not allowing it to go to rest? also, can the idle be slowed down a trifle?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
