Also no mufflers on the break in correct ? And 30mins is still the time to shoot for yea ?( my neighbors hate me anyway, good thing I am moving soon lol)
-Mike
Muffs or not.. no matter... your playing at about 2000
rpm and fluctuate the rpm up to about 2500 rpm
EDIT
have you assembled this yet... I think you MIGHT have
screwed up buying your push rods so early... normally
you test the PR length when you mock up AFTER all
the machine work is done.. if the block is decked or
the heads are cut or you change head gasket thickness
any or all of these factors will change the PR length..
I hope your OK
![](/ubbthreads/images/graemlins/wave.gif)
