Leakage at the governor sealing rings will be more pronounced when the fluid is warm, explains why it shifts better cold.
Gaining access to the rings requires removing the tailhousing, removing the tailshaft ball bearing (really HD snap ring pliers needed), the governor support snap ring and the governor cross shaft. The governor support is then removed from the output shaft to change the rings.
The INTERNET, the MISinformation superhighway
