Could not find anything on this when doing a search so here goes. Anyone have a solution to make the rear drum brake with cable style self adjusters actually work. Replaced the rear brakes on my 79 D-100 with all new parts, everything including return springs and adjuster cables are new. They don't seem to be adjusting, someone told me they will only adjust when applying the brakes while backing up. Is this correct.
